News
Stripe reconnection required
Related products:Connectors
  • June 13, 2025
  • 0 replies
  • 16 views
Sonja Kukkula
Forum|alt.badge.img
We have migrated our Stripe data source to a Stripe App to take full advantage of all the Stripe features. Due to this migration, all Stripe data source users need to switch to the Stripe App by July 15. To switch the Stripe data source to use the Stripe App, all users need to log in to Stripe again.
As soon as you can, please reconnect your Stripe account using the steps in the Stripe connection guide. If you have multiple Stripe accounts, you will need to repeat these steps for each account.
In case reconnecting generates a separate new connection, you can go to Supermetrics Hub and replace the old connection with the new one to ensure your queries continue running uninterrupted.
We will retire the old Stripe connections on July 15, 2025, so please reconnect the Stripe data source by then to have a smooth transition.
