We are upgrading our Shopify data source to a newer API version (Shopify API v2024-10). This upgrade needs the user to accept additional permissions to fetch location-specific fields. To accept the new permissions, you need to reconnect the Shopify data source.
You need to reconnect the Shopify data source after June 18, 2025, if you use the “Location name” dimension in your reporting.
Follow the normal connection steps, and you should see the “Update data access” request showing the new permissions. Accept those and complete the connection process. If you do not reconnect Shopify data source after June 18, you will get an error message asking you to reconnect to grant the permissions.
