Solved
Transforming/Blending data for Looker Studio - visualisation speed load times
  • July 25, 2024
  • 2 replies
  • 108 views
CraigIsAlwaysLearning
Supermetrics community,
A couple of years ago using Supermetrics and Looker Studio, I have always preferred transforming/blending data in Google Sheets before importing to Looker Studio to improve the load times of Looker Studio visualisations.
As it’s been a couple of years since I’ve used Supermetrics, and just jumping back in, does anyone have best practice guidelines, or their own processes, to have fast load times in Looker Studio? I used to find the native connectors slow to load, especially if blending was involved.
Thanks in advance,
Craig
Best answer by dataviz
Hi Craig,
Here is my experience with these two options.
Looker Studio + Blending
This is the option I use when I’m not 100% sure what I’m doing and still in the process of changing my mind. Looker Studio connectors give you immediate access to all dimensions and metrics, which makes it a great exploration tool.
However, because each time you load a report it makes a connection to the API, it is a bit slower than data from Google Sheets – depending on the API/connector (It is mostly the API that is slower, not the connector). As soon as you start blending data from two connectors, this difference becomes more noticeable.
Data Prep in Google Sheets
As the title suggests, you do a lot of work in Google Sheets. What you are basically doing in many cases is re-aggregating the data (I will do a quick demo on this topic in the next webinar).
The downside here is that each sheet can’t have more than 9 dimensions, so a bit of planning is required. Dont’t forget, you will need to switch between Sheets and Looker Studio, which may not feel intuitive.
As long as you know where you want to go and speed is your main factor, working with Google Sheets is a great method.
Data Warehouses
Using Google Sheets is basically a first step towards a data warehouse. There is a limit of 1 million rows in Google Sheets. If you hit this limit, it’s time to switch to something more elaborate.
Hope that answers some of your questions.
ralph
dataviz
Forum|alt.badge.img+1
  • Supermetrics Team
  • Answer
  • July 25, 2024
Hi Craig,
Data Warehouses
ralph
@dataviz - that’s an informative and awesome answer. You shed light on a future state for our operations. Thank you. I’m also keen to see your next webinar!
